Hey guys.I desperately need some help from you with my ongoing no fire issues.I have a couple active posts here http://fiatspider.com/f15/viewtopic.php?f=5&t=33092
I am afraid that with all the removing and replacement of components that I now have my coil wired wrong! It just doesnt look right to me.My wiring diagrams have confused me even more.It is a 82 f.i. car.Could someone post a pic of their coil or an explanation of their correct wiring?
I currently have the pink from ignition,red from control module,and yellow on my + terminal of the coil. The_ side has my black from condensor,black from control module,and the brown/white from ignition. Also,upon removing my coolant recovery bottle, there is a white wire with a spade terminal connected to nothing! It is coming thru the firewall with the ignition wires.There is the #2 printed on this white wire.
Thanks for any clarification.I am really frustrated
Need some help!
- ga.spyder
Need some help!
Craig Nelson
Fling It Around Turns !
- ga.spyder
Re: Need some help!
I have been searching old posts and found one with a pic.I was wired wrong and the car is running as we speak.The white #22 wire is an 'extra' and isnt connected to anything on the Spider. Now that it is running,I hope I can run down my intermittent issues.Thanks to this site for working...as it has for years!!
Craig Nelson
- ga.spyder
Re: Need some help!
Update....I ran it for 1/2 hour.Idles great,revs freely.I let it sit for a while and it wont restart,but I do have spark.Am I looking in the wrong place? Fuel related? Any offers on a award winning 82 Spider?
Craig Nelson
- 124JOE
Re: Need some help!
check the fuel rail pressure
- ga.spyder
Re: Need some help!
Thanks Joe.I am starting to think it is fuel related too.
Craig Nelson
- courtenay
Re: Need some help!
Check to see if the fuel pump comes on when you turn the ignition on and move the "pointer" in the AFM a bit. I had an issue where my '80 Fi would start when it was cold but not when it was hot. For some reason, the fuel pump did not want to work when hot. Changed out the pump and all OK.
Bruce Shearer
'80 Spider Fi
'10 Volvo XC70
'06 GMC 1 Ton PU
'80 Spider Fi
'10 Volvo XC70
'06 GMC 1 Ton PU
