OK A SHORT ALIGNMENT QUESTION
An Internet search brought up a number of good sites that define alignment terms, it also said that most manufacturers list TOTAL TOE which is to be divided by two. One half applied to each wheel. None of the Fiat specs indicate if the 1/8" is the Total Toe or if it is the toe for each wheel. Anyone know? RB
- SP3
- Your car is a: 1966 Ducati 250 Monza
Re: OK A SHORT ALIGNMENT QUESTION
1/8" each is fairly std for street cars over the last few decades.
http://www.fiatspider.com/f15/viewtopic ... 14&t=27922
- hayesbd
- Your car is a: 1973 Spider
My factory shop manual specifies 3mm +/- 1mm of total toe-in, laden. This is for sedan, coupe, and spider through at least 1974. I don't have info on later models.
Hope this helps,
Brian
Hope this helps,
Brian
Current: 1973 124 Spider
Previous: 1961 600D, 1970 850 Racer, 1973 124 Special, 1974 124 Special TC
- azruss
for years i set my own toe-in by using a tape measure between the front and back of the tire. I would use 1/8" total and would get 60k miles out of a set of tires.
