Hi,
I'm trying to decide if it's worth upgrading my carburetor on my '77. Currently running a 32 ADFA. Question: how much of an upgrade is the 34 ADF or the 32/36 DFEV? I'm planing on a new exhaust as well. Mine's a 4-1, Vick's 4-2-1 header and pipes seem well prices but love to hear from someone that has installed a set as I know you get what you pay for. Note: engine is stock with 74,000 miles. Thanks,
Carburator upgrade?
- DaveMarcotte
- Patron 2021
- Your car is a: Fiat Spider 1977
Carburator upgrade?
Dave From Ottawa, Canada
https://goo.gl/photos/wm7Yzxf1KoB1nwYJ8
Re: Carburator upgrade?
34adf is excellent
- Nanonevol
Wouldn't think a header is necessary unless you do plan on other performance upgrades. A stock 4-2-1 manifold is worthwhile however and not expensive.
1977 Fiat Spider
1985 Jaguar XJ6
1966 BSA Lightning
1985 Jaguar XJ6
1966 BSA Lightning
- DaveMarcotte
- Patron 2021
I'm having a heck of a time locating a 4-2-1Nanonevol wrote:Wouldn't think a header is necessary unless you do plan on other performance upgrades. A stock 4-2-1 manifold is worthwhile however and not expensive.
- Your car is a: 1977 Spider
I have a 4-2 manifold for sale. I have a 77 California car with the exhaust under the passenger seat, and I was going to use it with a 79 downpipe, but because the 2000 engines are taller it's gonna be a lot of messing around to get it to work. If you're interested let me know. One of the downpipe stud mounting holes is stripped out, but I should be able to get to welded and rethreaded.DaveMarcotte wrote: I'm having a heck of a time locating a 4-2-1
Also, my car came with a 32/36 DFEV and I like it well enough, but if I were to pick one personally it would be either a 34ADF or a set of IDF's (which is what I'm going to do eventually).
- DaveMarcotte
- Patron 2021
Thanks but I'll holdout for 4-2-1 as there's not cat on the car so unless I'm mistaken, an earlier 4-2-1 should fit without a retro fit. I think I'll order a Chinese 34ADF from ebay price is right.ebrown0104 wrote:I have a 4-2 manifold for sale. I have a 77 California car with the exhaust under the passenger seat, and I was going to use it with a 79 downpipe, but because the 2000 engines are taller it's gonna be a lot of messing around to get it to work. If you're interested let me know. One of the downpipe stud mounting holes is stripped out, but I should be able to get to welded and rethreaded.DaveMarcotte wrote: I'm having a heck of a time locating a 4-2-1
The manifold I have will work on your car, you would just need the downpipe from a non-convertor car like this: http://www.autoricambi.us/product/EX5-4 ... r-1973-74/.
I'll even throw in a brand new downpipe gasket!
- Nanonevol
That's what I did with my '77. Found the 4-2-1 , '79 down pipe and 3 bolt test pipe all on ebay and routed along the passenger side of the car. Low budget new exhaust system.
1977 Fiat Spider
1985 Jaguar XJ6
1966 BSA Lightning
1985 Jaguar XJ6
1966 BSA Lightning
Dave,
Just chiming in. Electronic ignition, 34ADF, 4-2-1 Exhaust and you'll be flying. Cheapest way to get more get up and go. One last thing, a lightened flywheel.
Then when you get tired of the 4200 RPM's at 70 MPH switch out the rear to a later 3.90 and drop the RPM's to 3800. So much better around town in 3rd gear too.
Good luck.
Good luck.
- DaveMarcotte
- Patron 2021
Really appreciate your input very much.Exit98 wrote:Dave,
Good luck.
I installed a Pertronix Ignitor ignition and then took it right out. Shuddered like crazy at 2500rmp? Thinking of spending the bucks on a distributorless if anyone ever get stock! Maybe a light flywheel for a next winter project also upgrade the brake
the lightened flywheel is a great upgrade, makes a huge difference!
- DaveMarcotte
- Patron 2021
I sent you a PM and email about that manifold?ebrown0104 wrote:The manifold I have will work on your car, you would just need the downpipe from a non-convertor car like this: http://www.autoricambi.us/product/EX5-4 ... r-1973-74/.
