Transmission interchange
Nitrate
Your car is a: 1981 Fiat 2000
Post by Nitrate »
1981 2000. In the Fiat 124 and 2000 models what transmissions are bolt in interchanges?. Any one know of sources for a good used one in NY, NJ, CONN, PA.? Thanks RB
SLOSpider
Re: Transmission interchange
Post by SLOSpider »
To my knowledge any Fiat 1800 or 2000 engines all had the same transmissions and bolt patterns
1975 124 Spider
1989 Chevy k5 Blazer
1967 GT Mustang Fastback
Nitrate
Post by Nitrate »
Thanks SLO. Can anyone else chime in and confirm they all used the same transmission? RB
ebrown0104
Your car is a: 1977 Spider
Post by ebrown0104 »
Everything I've ever seen references all internal parts to be more-or-less interchangable for all years. The shifter changed for 73-up, and I believe the clutch is different for 72-up, but if you stick to a 73 or newer it should go right on.
baltobernie
Post by baltobernie »
Speedo gear may be different, but they are easy to swap before you install it.
Surf65
Your car is a: 1982 124
Post by Surf65 »
With the help of Frank from Auto Riccambi in TX on parts, I have a great mechanic in North NJ who can do the job for you. He ordered parts pieces and gears needed and rebuilt my transmission like new. Very happy with work.
Please feel free to give me a shout to discuss and get details.
Regards,
Matt
973 202 8635
Nitrate
Post by Nitrate »
Matt, Thats a great lead, thank you. Mine is making an odd noise , I know it needs a clutch. Can he diagnose trans problems by driving and listening? RB
Surf65
Post by Surf65 »
Yes, he can diagnose and order all the parts from Auto Ricammbi. Probably not a bad idea to have clutch replaced when he has it out. You can buy a rebuilt trans but they are not cheap and probably makes more sense to have original rebuilt, keep original parts in car.
juvius
Your car is a: 79 spider
Post by juvius »
All the transmissions are interchangeable. The earlier cars had a smaller bell housing but those swap out as well....
Nitrate
Post by Nitrate »
Thanks Juvius. Makes finding one that much easier . RB
