I am looking for specs for attaching the hood / trunk round emblems. My recent
Paint work eliminated any reference points.
Also,the side Pinninfarina labels need to be relocated.
I could find another Spider and take measurements.(bad time of year to be looking for a Fiat)
Harvey
Badge Reattachment
Re: Badge Reattachment
Go to Google Images. You'll find a huge selection of Spider pictures from every angle.
Frog2Spider
'81 - 2000 Spider
Frog2Spider
'81 - 2000 Spider
The front and rear emblems sit in small indentations. Did the shop simply bondo those over? I don't think the emblems would look right if you mounted them. They would seem to pop out. Maybe demand the shop do the trunk and hood over and get it right.
The side Pinifarina emblem have 2 legs that go thru the rubber base. You may be able to rescue those exact locations by removing the interior rear panel and look for bondo pushed thru the original holes. Otherwise, break off the legs and epoxy the emblems in the approximate locations.
- azruss
early hoods had no emblem. As others have said, there should be a recess for the badges. The recess should be visible from the underside of the lids.
- Patron 2019
This previous post should help
http://www.fiatspider.com/f15/viewtopic ... on#p165859
Current 81 Spider 2000
Previous 76 Spider
Previous 76 Spider
