I have done a search here but can't find if there are any reproductions available for the Firewall ID Plate for my 1980 FI. Mine is a mess, has been all scratched up and is mostly unreadable. Does anyone know if these are being reproduced?
Pete
Firewall ID Plate Reproductions?
- spiderdan
- Your car is a: 1968 124 Sport Spider
Re: Firewall ID Plate Reproductions?
Dan
"Angelina"
2015 Toyota Camry XSE (hers)
"Angelina"
Exellent, thanks! A little rich with the shipping, but at least there is a source!
Now, does anyone know what the data is for the 4 Kg lines? (80 FI CSO California)
I can read a few of the lines, but not all, especially the 4 Kg lines.
Could someone post a proper (readable) pic of their '80 FI plate?
Pete
Pete
Found this. only French
http://www.fiat124spider.it/images/Dati ... rica_1.jpg
http://www.fiat124spider.it/images/Dati ... rica_2.jpg
Probably, the KG relate pollutant emissions, EPA, California, ...
I like more your old plate of the new ones .It is an original and has more value. Is its history
You can return it to new. Squeezing plate, grind, and silk screening.
Thanks, that helps a lot, the only info I seem to be missing is "E", the "version". Looks like the Kg data is unused on this plate, which makes some sense since it is on the door plate.
Not sure I would bother cleaning and screen printing this one, although it would mean I wouldn't have to imprint the numbers. Might make sense.
For the "E", I do not know.
Here you can find the manual in English. Left column, "Fiat 124 Spider America 2000" - "Libretto Uso Manutenzione IE 1981 -1982"
http://www.fiat124spider.it/datitecnici.asp
- azruss
My 80 does not have a firewall ID plate. It is in the drivers side door jam and made of plastic. My 70 spider had an ID plate like yours. I have not reproduced my ID plate but was planning on taking it to a laser engraver to have it reproduced in something besides plastic.With Laser engraving, nothing is printed, but etched, so it won't go away with washing or solvents.
Mine list the GVWR as 1284 Kg. and 2830 lbs.
AZRuss, I think your 80 is supposed to have the plate, it is probably just missing. Every manual I have shows one at the firewall and another at the drivers door jam.
Pete
Pete
- azruss
when I got the car it looked like an unmolested engine compartment sans a rebuilt AFM. the ID number is stamped in the upper cross frame of the firewall but no plate or hole indications of a plate like that. If anyone has pictures of the plate location i would love to see it.
Yep, mine has the stamped numbers there too, as well as the plate. The plate is directly under the stamped numbers. Mine is off in this pic, but the 2 mounting screws show the location clearly. I wonder if it was a CA only thing?
- seabeelt
- Patron 2019
Pete, All of my Spiders have had them.
r/
r/
I think it is likely that AZRuss' plate is just missing.
