Dual points for performance?
1978 Spider
Since the start set of points are missing along with most of the ancillary pieces to switch from start to run contacts I WAS WONDERING.....
Would it be possible to run both sets of points simultaneously while wired in series for additional coil saturation and hotter spark?
Re: Dual points for performance?
yes, that's what most dual points systems are used for
- bradartigue
They're 10 degrees apart, so maybe. Get a second coil and bypass the ignition relay. It would be unique for sure, you could get a badge for "dual fire"
Doppio Fuoco
Doppio Fuoco
1970 124 Spider
http://www.artigue.com/fiat
you don't use a second coil, the points overlap creates longer duration
it will depend on what the point gap is, longer coil saturation time will create a hotter spark. Do you know what the max output your coil has?
Gapped points at .018"So Cal Mark wrote:it will depend on what the point gap is, longer coil saturation time will create a hotter spark. Do you know what the max output your coil has?
Aftermarket Bosch coil
- bradartigue
I'm lacking the brains to figure this out. They're 10 degrees apart, not firing at the same time...so you're collapsing the field on the coil twice in succession, 8 times in a revolution instead of 4. It isn't a continuous delivery. Using two coils would do the same time as one - and deliver stronger spark.So Cal Mark wrote:you don't use a second coil, the points overlap creates longer duration
No?
1970 124 Spider
coil saturation occurs when the points are closed, that's what the dwell reading is. So you don't collapse the field twice, it only happens when both sets of points are open. So even though one set opens, you still have a path to ground through the second set.
As for the points setting, you'd have to compare dwell specs before and after to start to calculate the benefit and look at coil output on a scope
So Cal Mark wrote:coil saturation occurs when the points are closed, that's what the dwell reading is. So you don't collapse the field twice, it only happens when both sets of points are open. So even though one set opens, you still have a path to ground through the second set.
Now what I need that set of tubes in your avatar!
btw, Carquest points aren't an exact replacement. They will work and are good quality.
- Your car is a: 1970 128
- bradartigue
Yeah - you're right - you'd need that dual setup like some of the Alfas. I'm not thinking it through...fiatfactory wrote:no,bradartigue wrote:
No?
if the dwell was 50 degrees with one set of points gapped correctly, then because they are 10 degrees apart the new dwell will be 60 degrees (theoretical numbers)
To run two sets of points and two coils would need a distrbutor cap with two coil posts...
SteveC
1970 124 Spider
the alfa system is something completely different, dual points overlapping will create a hotter spark but don't expect miracles. The coil is still a limiting factor. I haven't seen any studies on whether coil life is shortened due to running them closer to maximum output all of the time. And of course, points begin wearing as soon as the distributor starts turning, so they are the least accurate method of controlling spark output
- bradartigue
Seems pointless (no pun intended) since electronic systems will achieve and exceed the desired result. This just sounds like an opportunity to either burn up your tach, shock the piss out of yourself, or eat coils up frequently.So Cal Mark wrote:the alfa system is something completely different, dual points overlapping will create a hotter spark but don't expect miracles. The coil is still a limiting factor. I haven't seen any studies on whether coil life is shortened due to running them closer to maximum output all of the time. And of course, points begin wearing as soon as the distributor starts turning, so they are the least accurate method of controlling spark output
1970 124 Spider
Thanks for responding, I didn't shock myself and my tach still works perfectly. When my coil fries I'll let you know.bradartigue wrote:Seems pointless (no pun intended) since electronic systems will achieve and exceed the desired result. This just sounds like an opportunity to either burn up your tach, shock the piss out of yourself, or eat coils up frequently.So Cal Mark wrote:the alfa system is something completely different, dual points overlapping will create a hotter spark but don't expect miracles. The coil is still a limiting factor. I haven't seen any studies on whether coil life is shortened due to running them closer to maximum output all of the time. And of course, points begin wearing as soon as the distributor starts turning, so they are the least accurate method of controlling spark output
(one in every crowd)
