I installed a Bosch wiper motor on my Spider from a 70s to 80s VW/Audi on my 80 Spider.
Bosch:
Marelli:
It bolts right up but requires soldering a ground wire to the body of the motor to get the intermittent wiper function to work. I did have this on my webpage but when I switched providers, my webpage died along with it but still have the wire configuration written down somewhere. I can post if you want.
By the way this shouldn't have anything to do with my delay issue. That problem started after installing air conditioning. The delay function has worked well on this Bosch motor for years up until the AC installation.
The Bosch motor works much faster but still wants to drag if it's cold outside or I need to put some Rain-X on my windshield. Ironically, the wipers work great in downpours! It's in the early hours of the morning if it's cold trying to swipe dew off the windshield that they struggle.
I've come to the conclusion there is still too much of a voltage drop between the ignition switch, wiper speed switch and selector. Despite replacing all the corroded grounds on the car.
My plan is to install a 12 to 15 volt step up converter. I've got this one on the way:
My theory is by connecting to the fuse that powers the wipers, by the time it goes through all the switches, I should be getting anywhere from 13.5 to 14 volts directly at the motor which should boost the speed.
I read where someone on the Xweb forums did this to an X 1/9 and it worked very well but have not been able to find it in the archives.
I'll post my findings are I get it wired it.
