This is me with my 1969 Fiat 850 Spider. 4th owner. I purchased it from a nice Italian man who had moved to the states and decided he wanted an Italian car. I'm in California, and have randomly met another driver with the same car in blue - an excellent connection to have made.
Current heartaches:
- Cranking driver's side window down unlatches the door (fun!)
- Bad door bushings, both sides sag and can fly open if not closed correctly, frightening both drivers and passengers
- Choke might not be working (has almost no play)
- E-brake doesn't always catch; not good since I'm in a hilly city
- Rear engine cover needs some love; it has actually been en fuego - I am dreaming of a full body job to deal with it
Tiny headaches:
- 61k miles; due for oil change (ordered my o-ring today, I made my own instructions, but I'm new here so feedback is good)
- Bonnet isn't watertight, some weatherstripping missing; haven't root caused it yet
- Replace heater fan switch (switch is all corroded, can clean, but I think it needs to be replaced too - direct connection is fine)
- Replaced rear gasket on soft top; new one is so thick I cannot seat the clips with it on
- Aux Throttle pull absolutely not connected
Projects I'm interested in:
- Cleaning up/dressing up chrome
- Adding right side mirror (so many bicyclists where I live)
- Dashboard - faux wood -> real wood (does anybody have a template? Passenger side was once replaced, and is wrong size.)
- Tweak side markers to function as turn signal indicators (does this require more relays? http://www.danielsternlighting.com/tech ... flash.html)
- LED indicator conversion, including headlights
- Re-cover dashboard: https://www.youtube.com/watch?v=ANE0dueAXSI
