How do I replace my cowl vent grills?
TFichter
Your car is a: 1982 Fiat 2000 spider
Post by TFichter »
Hi! Can anyone explain to me the best way to replace my cowl vent grills? I have removed the cowl but it seems that there is a great deal of spot welded sheet metal in my way. I have a 1982 2000 spider.
Tom
1982 Fiat 2000 Spider (2013- ?)
1973 BMW 3.0CS (owned 1991-2013)
1980 MGB (owned 1984-1991)
1973 BMW 2002 (owned 1987-1991)
1972 Fiat 124 Spider (owned 1974-1978)
azruss
Re: How do I replace my cowl vent grills?
Post by azruss »
there are a couple of flat clips about 2" long that secure the plastic pieces. remove those and you can slide the plastic pieces out without having to mess with the rain deflector.
4uall
Post by 4uall »
Clip can be seen on the left with the spray hose :wink:
TFichter
Post by TFichter »
Thank you! I guess that means I can leave the windshield wiper motor in place too!?
There should be a solid plastic weather shield and rubber vibration pieces sandwiched between the motor and the plastic vent grill. I remove the entire wiper motor/arm assembly to access the plastic vent grills. There are 4 bolts at the motor bracket to remove and the 2 nuts on the wiper arms for the assembly to be lifted off the cowl.
4uall
Post by 4uall »
Wiper motor/shaft 10mm nut
azruss
Post by azruss »
There are 3 rubber screws that need to be removed before removing the grill. Most of these screws are old and brittle and you may ruin them removing. AR has new replacements
TFichter
Post by TFichter »
Thank you all. I figured some of this out before your last replies but I was able to replace the grills by only loosening the wiper motor bolts, removing the metal clips as well as backing out the rubber screws. Then I slid both vent grills out the wiper motor end of the cowl. I was fortunate that the rubber screws remained healthy. However, the thin plastic shield that fits between the wiper motor and the grills was very brittle and cracked but it was repairable.
