Melted Wires
danny910
Melted Wires
Post by danny910 »
Have melted wires in dash. also a short in the alt. wires. What is the easy's way to remove the dash?
Re: Melted Wires
remove the instrument cluster and unplug all of the connectors. There are mounting bolts in the corners of the dash
danny910
Re: Melted Wires
Post by danny910 »
will work on that tomorrow. Thanks
mdrburchette
Re: Melted Wires
Post by mdrburchette »
I found if you remove the two forward bolts to the steering column and drop the steering wheel, it makes it a lot easier to remove the intrument panel. One you've removed that and marked all your wires, there are a few screws in the front part of the dash and two bolts at the back of the dash, one on both sides of the defrost duct area that need to come out for the dash to be removed.
