Head work
MrJD
Your car is a: Looking to ask questions about a 79 2.0
Head work
Post by MrJD »
Looking for an opinion:
I am going to be running a 1.8 style head on my 2.0 stock block and will get a bit over 9:1 compression. (don't ask how, long story, just accept it).
The head will be ported a bit and generally cleaned up professionally.
I have two questions: which cams should I use,
and two
Would the engine benefit from larger valves with new cams?
Carb will be a 34ADF on a single plane manifold. Exhaust: 4-2-1 manifold, 2" pipe with no cat and a free flow muffler.
vandor
Re: Head work
Post by vandor »
with the CR get some mild performance cams. Really hot cams need more compression.
If the head is ported then you can benefit from larger valves.
Re: Head work
second that, get some street perf cams with that setup
MrJD
Re: Head work
Post by MrJD »
Mark:
285V - street performance, power range 2800 rpm - 6800 rpm, slightly lumpy idle. Specs: 285 duration, .385 lift.
or
284V - Stage 1 - performance cam for engines with mild modifications; free flow exhaust, higher compression and more carburetion than stock. This cam will make great power from 3500 rpm to 6500 rpm. Specs are 280 duration with a .397 lift.
decisions decisions? recommendation?
