Which tire is a better bet??
So i have decided to put 4 (5 including the spare) new tires on my 13x6 cromodoras. I have narrowed my search down to either Sumitomo HTR-200 or Falken Ziex ZE-512 in 185/60/13. Let me know if anyone has had experience with either of these tires or have an opinion one way or the other. Thanks!
What about Yokos
I am now considering a third option: Yokohama Adiv T4 186/70/13. Anyone had a set of these on their car?
Re: What about Yokos
there are a lot of guys using these on my aerio forum. they seem to really like it. I've got Kuhmo Ecstas ASX on my aerio and I love them. they are an all-season though.kapman001 wrote:I am now considering a third option: Yokohama Adiv T4 186/70/13. Anyone had a set of these on their car?
I originally had the Ziex, great tires. Personally I like their profile and characteristics much more than the Avids. I've driven both but the Avids were on an Alfa. Just to give you an idea what I mean about their profile, the Ziex have a more square edge to them, so the sidewall goes straight up from the rim to the tread, the Avids are more rounded. The Avids are a little softer compound also..... I vote Ziex.
2 votes for Ziex!
Thanks for the responses! About the Ziex, I too agree I like the profile better on these which is actually one of my reasons for moving away from "i want the cheapest tire you have". No problems with these tires giving way in turns? Thanks!!
giving way? no. they have a pretty tough sidewall for a midrange tire. in fact I really liked those tires except that the wheel wells on my car were severly underfilled. here's a picture:
of course its not on the ground.. I dont remember if you've seen the car with those wheels or not.
the new wheels are 15x7 panasports with falken azenis. mmm sticky tires. mmm
-Jason
-Jason
Sorry, this is kind of unrelated...however...
Pastaroni, In the pic I see a bunch of lug nuts just laying there. Is that also a stud I see there? What do you guys use for the lugs?
When I first took the wheels off my car, I foudn that someone had taken normal studs from another car, and cut the heads off. They then have them screwed into the rotors/hubs, and then screw on normal lugs to them. I don't like this setup, as I've found sometimes the studs only go into the nut a few threads, and more into the hub, or vice versa and I feel this is dangerous.
I don't want to buy the lug bolts from one of the stores, since they're SO expesive (and I need a set of steel and aluminums
). So, what do people do with this? is there a better way to use studs, or do people but in permanent studs, or I was even contemplating welding, but I really don't want to permanentls change anything...
Just thought I'd ask since the pic is right here...
Thanks!
Thanks!
Yes those are studs, the type you described as not liking. I too share this belief. Currently I use wheel adapters with permanant studs on them. I dont know of anyone who has installed permanent studs on the OEM parts however. This seems like it would be quite a hassle to setup in my opinion. Right now I have some nifty aluminum wheel hubs with perminant studs waiting in the wings, woo for unsprung weight! These would be a pleasant solution for the front but the rears are a different story. I still havn't come with with a good design for them.
-Jason
-Jason
