Bumpers
fiat218
Bumpers
Post by fiat218 »
I was just reading the laws ,Minnesota/north dakota
I need bumpers or I will be stopped and I'm sure getting a ticket or fix it ticket. So I might as well avoid that before that happens
I was looking thru IAP parts , I can get the front and back shock or whatever the names are, they will slide in the original hole then I can get a custom bar made to go across the front and back,
I did not see anything for the rear,other then a shock boot?
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
narfire
Re: Bumpers
Post by narfire »
hey Jim, what some have done was to "push" the original big tube bumpers in a bit closer to the car. They drilled a hole in the shocks and drained the oil and then drilled through and bolted in position. Kind of a in between fix. The pics I've seen of this mod looked pretty good.
fiat218
Re: Bumpers
Post by fiat218 »
narfire wrote:hey Jim, what some have done was to "push" the original big tube bumpers in a bit closer to the car. They drilled a hole in the shocks and drained the oil and then drilled through and bolted in position. Kind of a in between fix. The pics I've seen of this mod looked pretty good.
It never came with any period
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
mpls124
Your car is a: 1974 124 spider 73 850 spider 76 BMW2002
Re: Bumpers
Post by mpls124 »
If it is registered as a collector you don't have to worry.
76 BMW 2002
fiat218
Re: Bumpers
Post by fiat218 »
It is not
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
