NRG Wood steering Wheel up-date
fiat123
Post by fiat123 »
Image[Im thinking of installing the NRG Classic wood steering wheel on my 1981 Fiat Spider Black/Tan Inter. Does anyone have one of these wheels in their car.Thanks Vinny
Just purchased NRG wood wheel from ebay photo to follow when i recieve it and install $170
This is the new NRG Wheel
SLOSpider
Re: NRG Wood steering Wheel up-date
Post by SLOSpider »
Looks better than the OE one! Where did you get that clock?
1975 124 Spider
1989 Chevy k5 Blazer
1967 GT Mustang Fastback
divace73
Post by divace73 »
nice look, also interested where you got that from, does the side spokes interfere with the view of the gauges?
From the pic it looks like the horn button is underneath it?
Cheers David
see my >>You tube channel<<
rodman
Post by rodman »
I would suspect you could do that to your steering wheel if you had any knowledge in wood working yourself...
divace73
Post by divace73 »
rodman wrote:I would suspect you could do that to your steering wheel if you had any knowledge in wood working yourself...
I have been thinking about that, but no doubt if I add my time plus the timber and the amount of mistakes I'll make along the way sometimes it is easier to just buy it, I do often like the journey on most DIY builds but sometimes you just need the destination...sometimes....
Cheers David
rodman
Post by rodman »
When I get too that point in my build I will try it just for the hell of it.... :mrgreen:
fiat123
Post by fiat123 »
divace73 wrote:nice look, also interested where you got that from, does the side spokes interfere with the view of the gauges?
I removed the center trim ring over horn No interference from spokes Purchased whell on e-bay for $100
georgeramos
Your car is a: 1971 124 Spider 1608
Post by georgeramos »
http://www.mgexp.com/article/diy-wood-s ... eel-2.html
great article on a DIY steering wheel. this dude did a gorgeous job. As a PRO WOODWORKER I do not have the confidence to do this project and he spells it out really well. I think its the compicated (to me) math involved. if anyone can figure it out mathematically and send me drawings i would attempt it and if it works i'll make you one.
my idea would be to use an oem early spider rim but to chrome plate the spokes...
george
azruss
Post by azruss »
the length of the piece is determined by the diameter of the steering wheel and the width of the wood. the cut is a 30 degree cut on both ends. the problem is each cut compounds the error, so you last cut will be custom. the easiest way to test your measurements is to cut in out of paper and tape it together first.
htchevyii
Patron 2022
Patron 2022
Post by htchevyii »
He seemed to know what he was doing and it still took 23 hours and cost $108. With my woodworking abilities, I would probably screw up several times, so I'd be better off spending whatever if cost to buy one. Pretty neat if you've got the skills, though.
Trey
