Post pics of your spider lowered ,
Can everyone post pics of there spider lowered , with they types of springs u have maybe even before and after .
- jfrawley
- Your car is a: 1982 Spider
Re: Post pics of your spider lowered ,
Before
After taking one round out of the front and 1.5 rounds out of the rear stock springs.
Wow looks so much better what an improvement !! How is the ride now ?
What size wheels was that spring lowering done with?
This is a shot of my Spider when I first got it. The factory springs where heavily cut by the Jerrari shop and were basically shot when I got it. (the link shows the photo better)
Here it is today after a set of lowering springs were added. The springs were a set of the yellow springs from Vick Autosport with one coil cut off. I am contemplating cutting one more off to get it closer to where it was when I got it.
wow love that color !!! do u know the color code it looks like positano yellow thats the color i want to make the green 69 i just got
- Curly
Kings Springs - Catalogue Numbers: Front KFFL-60, Rear KFRL-61(rears are a progressive rate spring)
http://www.kingsprings.com.au/catalogue ... alogue.pdf
Wheels are 15x7 with 195/50/15 tyres.
Curly from Oz
It is Positano Yellow. I liked the color enough that when I restored my 88 BMW 325is, I painted it the same color. It's not something you see all too often now days.akavinn1 wrote:wow love that color !!! do u know the color code it looks like positano yellow thats the color i want to make the green 69 i just got
BTW, congrats on the '69 Spider. I am a fan of the early AS series Spiders. I've owned a '77 and '76 and the build quality of the '69 seems to be a notch above my other Spiders. Little things like the real wood dash, engine lighting and enameled badges stand out. Plus, they seem a bit more rust resistent than the later cars, but that might just be the luck of the draw for my car.
Tim
That's a really nice looking Spider.Curly wrote:Kings Springs - Catalogue Numbers: Front KFFL-60, Rear KFRL-61(rears are a progressive rate spring)
Tim
- jfrawley
With regards to the question of how the ride is...a little harder. However, it does seem to corner better. The turbo wheels are 14's with Falken 912's at 195/60/14.
JF
JF
- Redline
- Your car is a: formerly a 1971 Fiat 124 BC Coupe
Not sure if it applies to Spiders, but this is an interesting read on lowering, control arm angles, roll centers and the effect on handling of the Coupe:
http://turbo124.com/forum/viewtopic.php?f=3&t=6855
http://www.124bc.com
- divace73
Too Low
Just about right??
What ever you do, don't go too low, you will cause all sorts of issues and really upset the handeling. The A arms from the front view need to be parralell to the ground as a minimum, the T124 write up on suspension is worth the read.
I have changed the stub axles on my car as well, so that does change the stance.
Cheers David
see my >>You tube channel<<
- divace73
Don't know if you have noticed it is a once piece bumper, I reckon it look great, that is what I want, but I have spoken to Curly and it was quite a challenge to get that made.fiathead wrote:Curly wrote:Kings Springs - Catalogue Numbers: Front KFFL-60, Rear KFRL-61(rears are a progressive rate spring)
Tim
Cheers David
I certainly did notice that one piece bumper and was about to ask the question when I noticed your post. I'm not sure if I'm put off yet!
Curly, do you have a photo of the front bumper? (scrap that question... I just found your photo gallery. Sorry, I'm still learning
