Also, after all the issues (and expense) I had with my recent running/dying problems only to find that the main problem was a voltage drop through my ignition switch that caused my voltage input to the coil to drop, I decided to add a voltage monitor contained inside the armrest. I had an old panel meter that runs off a 9v battery that I configured to monitor my battery and coil voltage.
