ALIGNMENT
ALIGNMENT
72 124
front , casters left 2.1
right 2.6
CAMBER left . -0.6
right . -1.0
TOE left 0.10
right 0.20
total 0.20
REAR
chamber left . - 0.3
right - 0.4
TOE left -.05
right -0.40
total -0.45
thrust angle -0.45
IS THIS BAD OR GOOD
right 2.6
CAMBER left . -0.6
right . -1.0
TOE left 0.10
right 0.20
total 0.20
REAR
right - 0.4
TOE left -.05
right -0.40
total -0.45
thrust angle -0.45
IS THIS BAD OR GOOD
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
- v6spider
Re: ALIGNMENT
real close... is that laden or unladen?... the fiat service manual calls for the car to have the average weight of 2 persons with an additional 130 lbs to act as luggage weight!
Front suspension settings my FIAT Factory Service Manual:
total toe= .12" ± .039"
camber -.5° ± .5°
caster + 3.5° ± .5° (I think +2.5° is more reasonable here... less tire scrub)
Rear Suspension is nonadjustable...
Cheers!
Rob
camber -.5° ± .5°
Cheers!
Rob
http://www.v6spider.com
Re: ALIGNMENT
No weight .so is that unladenv6spider wrote:real close... is that laden or unladen?... the fiat service manual calls for the car to have the average weight of 2 persons with an additional 130 lbs to act as luggage weight!
camber -.5° ± .5°
Cheers!
Rob
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
- v6spider
Re: ALIGNMENT
Yes, makes a big difference on how the alignment turns out.
Re: ALIGNMENT
My 80 is going in for a alignment tomorrow, what should it be ,
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
- v6spider
Re: ALIGNMENT
Just as it appears in my first post from the FIAT Service Manual...fiat218 wrote:My 80 is going in for a alignment tomorrow, what should it be ,
Good Luck!
Re: ALIGNMENT
that what i thought, got it, thanks , i will assume they that all the years of fiats have close to the same alignment numbersv6spider wrote:Just as it appears in my first post from the FIAT Service Manual...fiat218 wrote:My 80 is going in for a alignment tomorrow, what should it be ,
Good Luck!
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
- opus10583
- Your car is a: 1978 CS1
Re: ALIGNMENT
Hi,
I had a bit of negative camber dialed in last time and will go for more next, looking for just about what you've got there, more like -.8L, -1R.
Took a lot of plow out of the old horse.
Mark
Mark
...Yes; I know what it means: Fabbrica Italiana Automobili Torino.
DOLCETTO: 1978 CS1; 10:1, DMS, 4-2-1...
ANDIAMMO: 2012 500 ABARTH
Acquista il Biglietto; Prendere la Gita! - Hunter S. Thompson
- opus10583
Re: ALIGNMENT
Hi,fiat218 wrote:that what i thought, got it, thanks , i will assume they that all the years of fiats have close to the same alignment numbers
There's an unladen spec Service Letter for 1980-1981, SL-000-49, 6-11-81, that doesn't differ much.
Same values for Caster and Toe, +.5deg -0/+.5 for camber.
PM me your email and I'll send you the PDF.
Mark
Re: ALIGNMENT
Email,jam@gra.midco.netopus10583 wrote:Hi,fiat218 wrote:that what i thought, got it, thanks , i will assume they that all the years of fiats have close to the same alignment numbers
Mark
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
- blurple124
Re: ALIGNMENT
Here's a question:
Can the alignment be completed accurately without the swaybar on?
It is giving me some trouble and I want to get the car aligned today.
Charlie
1997 Jeep Wrangler TJ Sport
- blurple124
Re: ALIGNMENT
majicwrench wrote:Yes
Your confidence brings me great relief!
Charlie
Re: ALIGNMENT
When I got my 1980 Fiat Spider in 2003, I had a local alignment specialty shop go through the front suspension and align it. Apparently, they did not add weight to the car.
Last year, it went on a couple road trips (1,600+miles and <400 miles). When I put it away for the winter, I noticed the inside tread of the front tires had worn completely away. There was a ~1" band of bright steel belt showing on each tire.
When I replace the tires and have it aligned this spring, I shall put ~500-650 pounds of weight in it. It is aggravating to have to do that each time the alignment is checked, but I guess that is the price of having such a nice little car, eh?
Re: ALIGNMENT
Was no weights added she I got mine done
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
