rotas and stuff
azruss
rotas and stuff
Post by azruss »
This is a public question for Mark.
I am rethinking wheels and looking at 15x6 rotas. Your website lists silver and gunmetal. do you have these in stock. do you carry any with black spokes. What do you recommend for wheel bolts.
question #2: looking at your dizzyless ignition system. have an 80FI with a flat hood and clearance is a problem. would also love to get that stuff away from the exhaust. Do you know if i can drive your unit from the old "1438" dizzy hole on this motor.
Re: rotas and stuff
in 15x6 we only have silver or gunmetal. The gunmetal are pretty dark.
Our ignition does drive from the left side of the block, just like the 1438. We designed it to cure the problem of flat hoods and 2l motors.
azruss
Re: rotas and stuff
Post by azruss »
thanks, mark. I'm getting very close on the body work. once it heads to the painter and i find out what it will cost me to paint, then i can make a decision on the ignition. still will need wheels, so i will be in touch.
