How to compress REAR brake piston
Taz
Post by Taz »
What's the secret to compressing the piston on the rear calipers so that I can put on new pads ? The front pistons compress using a C clamp no problem, The rears are another story. I know the piston screws into the caliper, I rebuilt one last year. When I looked up changing rear brake pads in my repair manual it said treat the rear as same as the front :?: I removed the bleeder, tried compressing with a C clamp and also tried screwing the piston back in, WON'T BUDGE :evil:
Hvnfn
Re: How to compress REAR brake piston
Post by Hvnfn »
I havent done the rears without rebuilding the caliper yet. :)
narfire
Post by narfire »
I think they only compress a little, most of the retraction is from screwing the piston in. Perhaps you picked up on it, but the line on the piston has to be towards the top/bleeder screw.
I have used a file to turn the piston in, but be carefull as they are brittle and can break if you push too hard. A piece of 3/4 inch wide flat-bar 1/4 inch thick works well. Last time I did the rears, I don't believe they retracted as far as the fronts. The pads have a tab that goes into the slot on the piston.
maytag
Post by maytag »
and if you;re like me, you may have missed that the rear pads are thinner than the fronts. :oops:
bobplyler
Patron 2022
Patron 2022
Post by bobplyler »
You have to screw the piston in. I use a tire iron to screw it in.
1979 Fiat Spider (since new)
1999 Honda Shadow VLX 600
Marmeister
Your car is a: 1980 FI Fiat Spider
Post by Marmeister »
Anybody have some specific instructions on rebuilding rear calipers? I've posted ("The infamous rear caliper challenge question, again") with more details about my confusion and my service manual shops 2 "disk" washers and a "thrust" washer, the "miafior rear caliper" article shows 3 "disk" washers and a thrust washer, and the caliper I removed had 3 disk washers and no thrust washer :roll:
And neither the service manual or the miafiori article show how the threaded plunger, the pawl (funny shaped wedge), etc, fit together !!
If any of you guys have already rebuilt rear calipers, please help ! :(
Adham
Marmeister
1980 FI Spider - "LUIGI"
Ottawa, Canada
81SPIDERMATT
Post by 81SPIDERMATT »
bobplyler wrote:You have to screw the piston in. I use a tire iron to screw it in.
brilliant
Post by RRoller123 »
Is it normal for it to take a really large force to screw the rear calipers in? I can barely get them to budge more than about 30 degrees. So now I am forced off the road until this is resolved, dammit. There is prior evidence of a vice-grip or huge pliers being applied to the pistons, and I basically can't get them to move at all. Unhook the hand brake cable? Bleed off some fluid? (probably buy new calipers?) Any help appreciated.
Pete
rlux4
Patron 2022
Patron 2022
Post by rlux4 »
They are very hard to turn if they haven't been done in a while. I use a large file that just fits the slot. I use it lengthwise, giving me plenty of leverage. After a couple of turns it gets easier.
Ron Luxmore
rlux2n2@gmail.com
Thanks, I will have at it in the morning. Was worried that there was something major wrong with it, but some brute force may convince it.
Man what a chore. I can't even guess what torque it took to turn the pistons in. A flat file, as suggested, worked really well. It remains to be seen if these calipers are ok; I will know when I get back on the road hopefully later today. Thanks for the input!
rlux4
Patron 2022
Patron 2022
Post by rlux4 »
If you lined up the notched side with the brake hose inlet you should be good. If they weren't leaking before they're probably OK, but did you change the seals and check the condition of the pistons and cyliders? If the pistons have been extended for a long time you can get pitting that will cause a leak when they're back down in the retracted position.
Ron Luxmore
rlux2n2@gmail.com
Yep, no leaks, they look ok, and the slot is lined up. I was just amazed at how much torque it took to get them to turn. It took about 6 full revolutions to clear enough width. The rubber piston boots are ok, no tears so re-using them. The new pads came with thin stick-ons that look like carbon fiber stickers; I assume these are anti-squeal pads and I should install them? (I did).
From the looks of things down there the rear brakes may have never been done. Unlikely but only 69K so possible? Hopefully back on the road today and all will be well! Want to make Cars and Coffee on Saturday!
Pete
RoyBatty
Your car is a: 1975 124 Spider - 1971 124 Sport Coupe
Post by RoyBatty »
This may help. Sorry I didn't post sooner.
http://www.fiatspider.com/f08/viewtopic ... brake+tool
Oh man I gotta get one of those! That will do the trick.
