Steering Wheel Switch
- Your car is a: 81Spider Pininfarina
Will a 1978 Fiat Spider Steering Wheel, fit on a 1981 Fiat Spider
Re: Steering Wheel Switch
Yes, but you will have to remove the adapter that the later wheel bolts to before you can use the early wheel.
Trey
htchevyii wrote:Yes, but you will have to remove the adapter that the later wheel bolts to before you can use the early wheel.
great! thanks for the tip.
