I bought my '81 FI in 2009 as a non runner. I just assumed the coolant overflow/recovery tank was stained from age and didn't pay much attention to it except to check levels when refilling the system after projects. I installed the flush "T" crossover above the passenger side cam cover as many do, but have still had a devil of a time "burping" it and getting air bubbles out after projects. Yesterday I let it idle for a while in the driveway and suddenly coolant began spraying out of the top of the overflow/recovery tank, and the temp gauge went to max. Today, I removed the overflow tank and hose to clean it. Washing it out revealed about 2" of leaves, acorns, and deformed mouse fetuses in the bottom of the tank. I have driven this car over 2500 miles, but over time, coolant dissolved much of that organic matter into a thick black glue that clogged up the tank inlet. It would let coolant in, but would not let it out. Apparently the seller of the car had not kept a cap on the tank until he was ready to sell it! If you are restoring one from long term storage, check it - it's a simple "first thing to fix." (If you don't think that opening is big enough for a mouse, think again.)
