Page 1 of 1
Dumb Toothed Belt Question
Posted: Sat Nov 26, 2011 3:50 pm
by jimmycakes401
I'm putting my engine back together. Many of you know that I did not take it apart. I have some manual files and a manual for a different type of Fiat. I have a 1981. Do I just have one belt that goes from the cam around the alternator, water pump and pulley? Anyone have an image? I have a belt. The PO took everything apart but had the new parts. If I knew what was going on, my whole engine bay would be together today. Oh well. I knew it'd be slow going.
Re: Dumb Toothed Belt Question
Posted: Sat Nov 26, 2011 4:04 pm
by jimmycakes401
It's fuel injected and it doesn't look like the alternator lines up with the same belt as the water pump would take.
Posted: Sat Nov 26, 2011 9:44 pm
by azruss
not great pix, but should help you out. these are an 80 FI. At first glance, they dont look like they align, but once you get the belt on you should be ok. As I recall, you can adjust the pull on the alternator shaft to help with the alignment.
Posted: Sun Nov 27, 2011 1:32 am
by boogiedude
The toothed belt(timing belt) goes from the main crank, to the aux pulley, up to the cams and is tensioned by the bearing. The water pump, alternator and air pump are all driven by vee belts and are independent of the timing system
Posted: Mon Nov 28, 2011 11:02 am
by jimmycakes401
Ack. I'm a moron. The water pump pulley was on backwards.
Anyone know if I can get a tee gasket anywhere local? I had ordered one for IAP and I seem to have misplaced it. Yet another tiny annoyance blocking the starting of my car.
