new version of our Computronix ignition
We've developed a new trigger unit that installs in place of the distributor on the 124 and 131. We now have the option of using the trigger in the block location or the exhaust cam location.
The unit is short enough that hood clearance is still improved. The only hitch is that you need to send in your distributor drive gear so we can set the new unit up for you.
http://www.youtube.com/watch?v=KPZvLBcsO4s
magi111
Re: new version of our Computronix ignition
Post by magi111 »
This site use full to all around the would, use it develop both…..
This site use of all the would and system news and helps known every one…..
Exhaust Shops
Ptoneill
Post by Ptoneill »
Mark,
I just bought the original computronixs system from you, I noticed on another string that someone asked about the lack of a vacuum advance. You responded that the advance was for fuel efficiency not performance. I am not by any means an expert, by not having a vacuum advance what should I expect from my engine's performance? Will it effect the idle or normal driving? I have an automatic transmission, does this make any difference?
Stay Safe,
Pat
79spider
HAVE FUN!! It's a FIAT!!
ptoneill@msn.com
you will have better performance, with no effect on idle. The auto trans won't make a difference. I packaged your system yesterday and it will ship this morning
Ptoneill
Post by Ptoneill »
Thanks Mark, I am looking forward to getting it. Hopefully the exhaust for Christmas! Any chance fot a sale?
Stay Safe,
Pat
79spider
ptoneill@msn.com
