Page 1 of 1
When buying a project, look to see
Posted: Tue Sep 27, 2011 11:27 pm
by sixcharlie
If the cross member, supporting the engine, has been welded in. A sure sign of some frame rail rot diagnosed sometime in the last 30 some years.
Why look?
Because it adds a few hours to the restoration project.
Re: When buying a project, look to see
Posted: Wed Sep 28, 2011 3:38 pm
by lm48
You got that right. I newer looked at this part of the car. Adding few hours only?, in my case was 2 weekends of cutting, grinding, welding, grinding and welding again, to rebuild the damage area before attaching the refurbished crossmember. Finally done
Posted: Wed Sep 28, 2011 9:22 pm
by sixcharlie
My "few hours" are still piling up.
Posted: Sun Oct 02, 2011 6:29 pm
by lm48
here are the results after 2 weekends. good luck with yours
Posted: Sun Oct 02, 2011 7:00 pm
by sixcharlie
Nice! I'm going to have to weld the new one in. Just finished getting the old one out...
Posted: Sun Oct 02, 2011 9:10 pm
by vandor
If you already have the welder out you might as well seamweld the crossmember, especially toward the ends, close to the studs.
Posted: Sun Oct 02, 2011 10:17 pm
by sixcharlie
vandor wrote:If you already have the welder out you might as well seamweld the crossmember, especially toward the ends, close to the studs.
Planning on that. Have to do it well because I don't want to have to do it again. Those welds were the hardest part of getting the bad crossmember out.
Posted: Mon Oct 03, 2011 11:05 am
by lm48
When I did mine I follow somebody advice from the forum and modified the frame to be able to use cylinder head bolts. This was the reason of so much welding. Know I can remove and install the crossmember relatively easy. This is an extra step but well worth.
