HI. New Member
HI. New Member
We just got a 1977 124. Failed emissions. Trying to tune it and the timing mark on the crank is nowhere to be seen. Where is this mark supposed to be exactly? Help!
- Your car is a: 1982 Spider
Re: HI. New Member
Welcome. You have come to a helpful site. Place your question under the "engine" section of the forum.
Steve
1982 Red Spider 2000
1919 Old Town Sailing Canoe
- 124JOE
Re: HI. New Member
hopde this helps ,its set to #4tdc
Re: HI. New Member
Timing mark should be on the plastic timing belt cover. On the drivers side down low by the crank pulley.
Colinsquest wrote:We just got a 1977 124. Failed emissions. Trying to tune it and the timing mark on the crank is nowhere to be seen. Where is this mark supposed to be exactly? Help!
Re: HI. New Member
Thanks all. I can clearly see the marks on the timing belt cover, but can not see anything on the crank pulley. Just surface rust. I will try again tomorrow.
- 124JOE
Re: HI. New Member
do you see the#4 in the diagram above
theres a groove all the way around it except for the mark
with motor STOPED,put your finger on the groove and feel for it
sliding your finger around the face of the pully ,you should find the mark
paint it with a dab of paint
i used white paint.
i used white paint.
Re: HI. New Member
Thanks for the help. I have quadrupled check the face of the crank pulley and there is no mark. The only indication of a mark are two small stamped notches on each rim of the pulley. They are really too small to be seen with a timing light, so I put tape the to see the spot better and timed off of that. Car runs just fine, but we will see about the emission test.
- 124JOE
Re: HI. New Member
to be certin about the crank
i pulled the #1 plug and put a long socket extention in there with a friend turned the crank untill the extetion was
at the highest point
and painted the spot with white paint "dot"
