need a answer
fiat218
need a answer
Post by fiat218 »
im looking at putting on a twin set of carbs on a 2L engine, it a 72 124.
my question is, will the hood shut properly?
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
Re: need a answer
are you using a flat hood? Do you have the dist in the cam housing? Did you use a 2L crossmember?
azruss
Re: need a answer
Post by azruss »
I put a 79 2L with twin DCNFs from Serra in a 70 spider. Flat hood, 71 crossmember. had the small rectangular air cleaners. had to modify the height of the front edge of the front one for fit. dizzy was up on top and wasnt as problem.
fiat218
Re: need a answer
Post by fiat218 »
i guess i know nothing in what i have at this time, sorry, and thanks for the answers, i did not realize things can be difficult. im guessing the cross member lowers that engine, i did read it higher then a 1608?
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
