as it has before but not this much any more and i would have lost its pearch
Have you noticed an appreciable difference with the rear bar? I'm thinking off adding one, but my car bites so well into tight turns now, that I can't imagine what more it could do for it.124JOE wrote:its all good its been on there for seven years
it seems to have all the space it needs
Where the front forged (flatened) ends of the bar attach to the frame, are there already holes in the frame, or did you have to drill them? Are they held to the frame with just cinching bolts, or do you have to blindly reach up and in and fasten a nut?124JOE wrote:hey guys im going to fix my pass side mount it seems to have sliped out
Check out these links for the instruction sheet and diagram. You have to drill two holes and slip a u-bolt inside the frame. The end-link bracket attaches to the ends of the u-bolt.SanRafaelFaz wrote: Where the front forged (flatened) ends of the bar attach to the frame, are there already holes in the frame, or did you have to drill them? Are they held to the frame with just cinching bolts, or do you have to blindly reach up and in and fasten a nut?
Thanks!
I have one in the front. I don't remember ever having it put on so I can only assume it came with it, and I'm the original owner.124JOE wrote:yes it goes just like the links show
to locate i had to fully asemble the sway bar kit and mark it
then remove parts of it drill then reasemble it
all and all id rather buy the bigger front sway than the rear
