Page 1 of 1
Boot Glue
Posted: Sun Jul 03, 2011 7:01 pm
by WYSpider
What kind of glue would you suggest I use on the boot and mirror control plug?
Re: Boot Glue
Posted: Mon Jul 04, 2011 10:30 am
by baltobernie
Contact cement. Apply to both surfaces and allow to "tack", per the instructions on the can.
Re: Boot Glue
Posted: Mon Jul 04, 2011 2:57 pm
by boogiedude
At work we use a weldwood contact cement that can be found at most hardware stores. Make sure it says for cloth/fabric/vinyl applications. You can also use 3M super weatherstrip adhesive for the mirror plug. It comes in a tube and works amazingly. Can probably be found at an autoparts store
Re: Boot Glue
Posted: Tue Jul 05, 2011 9:30 am
by WYSpider
Thanks I'll see what I can find.
Re: Boot Glue
Posted: Wed Jul 06, 2011 7:25 pm
by BEEK
3m yellow weather strip adhesive
Re: Boot Glue
Posted: Fri Jul 22, 2011 4:32 am
by WYSpider
3M super weatherstrip adhesive worked really well for the mirror plug. Haven't got around to doing the boot yet.
Re: Boot Glue
Posted: Fri Jul 22, 2011 2:27 pm
by boogiedude
you could use the weatherstrip adhesive on the boot too. The stuff works amazingly on anything. Especially plastic to vinyl. Just apply to the vinyl and the cap, not too thick or you might see "chunks" in the surface, let it set a bit then pull it on
