I have a '74 spider. The current shaft style radio is old and broken, is it simple to mount a new stereo that does not have shafts in the current location? I'm just not sure how to secure it properly.
New stereo
Re: New stereo
Hi redek
Can you post a photo of the radio and radio console ?
http://fiatspider.com/f08/viewtopic.php?f=18&t=12141 << Photo Link
- opus10583
- Your car is a: 1978 CS1
Re: New stereo
Hi,redek wrote:I have a '74 spider. The current shaft style radio is old and broken, is it simple to mount a new stereo that does not have shafts in the current location? I'm just not sure how to secure it properly.
I'm new here and have the same question, which I can't believe hasn't been addressed before. I see posts about cutting the shaft plate for DIN radios but nothing on constructing or buying any sort of DIN slide in mount to hold a modern radio unit.
Is there something completely oblivious I'm missing?
Mark
...Yes; I know what it means: Fabbrica Italiana Automobili Torino.
DOLCETTO: 1978 CS1; 10:1, DMS, 4-2-1...
ANDIAMMO: 2012 500 ABARTH
Acquista il Biglietto; Prendere la Gita! - Hunter S. Thompson
- opus10583
Re: New stereo
OK... Found this, just hadn't seen it before I posted, rushing to work...
http://www.detroittriumph.org/Member/rm ... _1122.html
Is that really all there is to it?
Mark
Mark
opus10583 wrote:Hi,redek wrote:I have a '74 spider. The current shaft style radio is old and broken, is it simple to mount a new stereo that does not have shafts in the current location? I'm just not sure how to secure it properly.
Mark
Re: New stereo
All I did for mine was cut the opening to fit the din sleeve, bend the tabs and JB welded L-brackets from the console to the sides of the DIN sleeve. It seems to work fine, my only issue is the depth of my Sony CD required me to put a 1/4" spacer between the sleeve and the console to clear the heater housing. As well, the bundle of wires must be carefully redirected over the side of the stereo as there lacks sufficient clearance for the main bundle of wires behind the stereo.
- opus10583
Re: New stereo
Hi Adam,Adam wrote:All I did for mine was cut the opening to fit the din sleeve, bend the tabs and JB welded L-brackets from the console to the sides of the DIN sleeve. It seems to work fine, my only issue is the depth of my Sony CD required me to put a 1/4" spacer between the sleeve and the console to clear the heater housing. As well, the bundle of wires must be carefully redirected over the side of the stereo as there lacks sufficient clearance for the main bundle of wires behind the stereo.
How deep is your Sony item and where did you get the spacer?
Mark
Re: New stereo
Hey Mark, my Sony is model CDX-GT420U and it is about 6.5" deep. I bought the spacer for $10 from a Best Buy car install shop. Too bad all the new digital media decks (no CD or tape) have iPod caddies and what have you. It would be nice to have a deck that is only a few inches deep.
- opus10583
Re: New stereo
Thanks!Adam wrote:Hey Mark, my Sony is model CDX-GT420U and it is about 6.5" deep. I bought the spacer for $10 from a Best Buy car install shop. Too bad all the new digital media decks (no CD or tape) have iPod caddies and what have you. It would be nice to have a deck that is only a few inches deep.
I rather like the iPod caddy but see the problem...
- opus10583
Re: New stereo
Hi Adam,Adam wrote:Hey Mark, my Sony is model CDX-GT420U and it is about 6.5" deep. I bought the spacer for $10 from a Best Buy car install shop. Too bad all the new digital media decks (no CD or tape) have iPod caddies and what have you. It would be nice to have a deck that is only a few inches deep.
Do your remember which particular spacer that was?
Mark
Re: New stereo
Just a generic one the installer grabbed off the shelf and charged me $10 bucks for... no receipt or anything
