Hardtop installation noise
I have just installed a hard top on the spider it is really nice. It takes away alot of the road noise and is great for winter driving my problem is in 4th and 5th gear there is alot of noise around 40mph and up to 50mph after that it gets quite again, kind of like a drone may be its the exhaust its like the top amplifies the sound I don't notice the sound with the soft top. Any ideas?
- spidernut
Re: Hardtop installation noise
Harmonics?
John G.
1977 Spider (Sold 2017)
1979 Spider (Sold 2015)
1980 Spider (Sold in 2013)
1981 Spider (Sold in 1985)
Maybe an exhaust vibration? I have the same problem with my X19. It buzzes at a certain rpm but every single one I've owned has done it.
What happens if you roll down the window a bit when it's making the noise?
- perthling
My 124 coupe has always suffered from this in the rear at around the 80km/h (approx 50mph) mark. Not really noticeable from the front seat though.
_______________________
Perthling
1974 Fiat 124 Spider (blade bumper 1756cc)
1974 Fiat 124 CC (same family since new)
1975 Fiat 124 CC (project)
1969 Fiat 124AC (project)
1997 Coupe Fiat 20VT (daily driver)
http://www.fiatlancia.org.au
Perthling
With modern sun roofs cracking a window helps.
Other than that, unless the top is vibrating probably not much you can do.
Think its the exhaust and there are mounts where the back hooks up that are in need of being removed they are rubbing on the car and not of any use. Well that problem doesn't really matter at this point it is ticking really loud. The engine is old I've got the original block I guess its time to put an engine together. Where is a good place to get the rebuild kit? I'd like to put a mild cam in it and the highest compression pistons I can get away with street purposes. I have to save some money for the exhaust. I haven't finished the countach yet its going to be difficult two projects going at once. Guess I will be reading the engine and performance section. Well at least I am looking forward to some good reading. I'd like to get hold of a Guy Croft book.
