Page 1 of 1
Pinstripes?
Posted: Thu Dec 30, 2010 3:43 pm
by Kent124
Does anyone know of a method to remove PO installed pinstripes from a car? Not sure if they are adhesive or some type of heat tape but they are ugly and not easily pulled up.
Re: Pinstripes?
Posted: Thu Dec 30, 2010 4:39 pm
by azygoustoyou
Take a hair dryer and heat them. Once you get the corner up. Slowly pull them up. They should come off.
Re: Pinstripes?
Posted: Thu Dec 30, 2010 11:04 pm
by Kent124
Cool. I'll give it a try.
Re: Pinstripes?
Posted: Fri Dec 31, 2010 12:59 am
by Zippy
If there is any adhesive remaining I suggest you try De-Solv-It.
http://www.orange-sol.com/household/index.html I have bottles of this stuff that are 25 years old that I still use to remove stickers from stores, tar, anything sticky. Great stuff.
Re: Pinstripes?
Posted: Fri Dec 31, 2010 2:37 am
by azygoustoyou
Is this a hint of your age there Zippy?
Re: Pinstripes?
Posted: Fri Dec 31, 2010 2:31 pm
by Zippy
Re: Pinstripes?
Posted: Fri Dec 31, 2010 2:38 pm
by samthedog
Goo Gone can be used after your get them lifted off using hair dryer.
It removes all sticky glues.
It's good stuff and sold at Lowes, and many other hardware stores.
Re: Pinstripes?
Posted: Fri Dec 31, 2010 5:42 pm
by mdrburchette
PPG also sells a solvent just for removing the glue from stickers without harming the paint. I just used it on my X19 racecar.
Re: Pinstripes?
Posted: Tue Jan 04, 2011 9:02 pm
by Kent124
Having some success with the pinstripes. One door was a piece of cake - the minimal glue left cleaned up using rubbing alcohol in just a few moments.
The other 3 panels I have done are slow going with tons of adhesive residue. Hair dryer helps lots. So does pulling on the stripes at an angle greater than 90 degrees - less prone to breaking.
Re: Pinstripes?
Posted: Wed Jan 05, 2011 2:13 pm
by Kent124
Followup: drenching a rag with rubbing alcohol and laying it on residual adhesive for several minutes make glue cleanup much, much easier.
