The next three are the blower that I took out of my totaled '76. I can't find any way to mount it in the car. It does not seem to have any attachment points either on the top where it would go up against the heater core, or on the bottom (which makes sense because it needs some space on the bottom for the lower vent to open.
I'm hoping someone can advise me as to how I would mount the blower so that I can have a working heater and defroster.
Is this the control that opens/closes the flow of hot coolant into the heater core to make it heat the air that would blow over it if I had a blower installed? If so, any advice as to how the cable that should be attached to it would actually attach to it?
-- se
