1980 Spider FI HELP!
- Your car is a: 1980 Fiat spider 2000
There is a yellow wire with heavy black insulation and a double terminal clip that I took off coming out of the firewall below the radiator overflow bottle. I must have forgot to lable it. Does anyone know off hand where it goes? Is there a double wire on the neg. terminal on the coil?
Re: 1980 Spider FI HELP!
Yes, it goes to the neg. terminal of the coil. The 2nd spade terminal accepts the brown with white stripe wire from the ECU. On my car this wire is in the same sheath as the pink wire from the ignition switch that goes to the positive terminal.
Thanks Ron.
