Carpet/Carpet Padding to Dynamat
ralphcap
Post by ralphcap »
I have finaaly finished repairing the floorpans on my '81 2000 FI. Not too bad but had the potential to get a lot worse. I installed DynaMat throughout. Just received a cheesy carpet set that I bought off ebay (you do get what you pay for). Question is what type of adhesive should I use to secure the carpet and, in this case, some pieces of carpet with carpet padding to the DynaMax. I hate carpet that slides all over the place. Nothing is more annoying.
htchevyii
Patron 2022
Patron 2022
Re: Carpet/Carpet Padding to Dynamat
Post by htchevyii »
I used spray adhesive, there are different strengths, the stuff sold for headliners is the strongest.
Trey
jfrawley
Post by jfrawley »
When I replaced my carpets I wasn't sure I wanted to have them glued to the surface, but I also didn't want to slide around. I did use adhesive on the more upright surfaces but used double sided carpet tape in a number of other spots to hold the carpet down yet be very easy to remove. Just a thought.
John Frawley
Frederick, MD
1982 Spider
http://www.dcfiats.org
meangreenspider
Your car is a: 1982 Fiat Spider 2000
Post by meangreenspider »
jfrawley wrote:When I replaced my carpets I wasn't sure I wanted to have them glued to the surface, but I also didn't want to slide around. I did use adhesive on the more upright surfaces but used double sided carpet tape in a number of other spots to hold the carpet down yet be very easy to remove. Just a thought.
This is the same method I used and I am happy with the results.
Fiat88
Post by Fiat88 »
I used 3M spray adhesive I picked up at Sears Hardware and also used hook and loop velcro in some places to make removing the carpet easier to access any wire.
ralphcap
Post by ralphcap »
Thanks for the suggestions. I'm going to use all three methods (spray adhesive, velcro and carpet tape) to secure the 10 pieces depending on the location of the piece.
