loose mirror
grittracing
loose mirror
Post by grittracing »
if you have a loose mirror you may be missing your spring.if so and you cant afford a new mirror. you can replace your spring with one out of a trailer tail light. found at any auto parts store. for about $6.00
wikkid
Re: loose mirror
Post by wikkid »
is this referring to the side mirrors or the the central rear-view mirror?
grittracing
Re: loose mirror
center ,sorry for the long delay
joelbert2k
Re: loose mirror
Post by joelbert2k »
I may be a little dense here but could you be a bit more explicit about this.
My mirror was messed up when I got it and I have no idea what this spring looks like or where it goes.
Joel
TulsaSpider
Your car is a: 1978 Spyder 124 2L
Re: loose mirror
Post by TulsaSpider »
Mine too!
laura79
Re: loose mirror
Post by laura79 »
Mine too!
Tobi
Re: loose mirror
Post by Tobi »
Same here!
Nick
Re: loose mirror
Post by Nick »
Me neither!
grittracing
Re: loose mirror
this is where the spring is in the canter mirror. you go to the auto parts store buy a $5.99 trailer (Stop and turn) tail light. they do sale just stop so be careful. than you take it apart and pull the spring out and replace it with the one in the mirror or the that should be in your mirror as mine was not there at all. i also pulled the clear glass out and stored it and mover the mirror glass forward to where the clear was. my clear was stained or faded or fogged. would not come off. there is a slit on the bottom of where the spring rests. compress the spring and squeeze it into place
hope this helps if you need more help feel free to ask -Tony
joelbert2k
Re: loose mirror
Thank so very much, Tony!
It all seems so clear now that I see it.
Joel
grittracing
Re: loose mirror
no problem as I find more grittracing fixes I will post them
