Here comes the part where I need help: I'm not the most educated person when it comes to how spring rates/heights and such work.
On IAP, their performance springs set consists of fronts that are 12 1/4" tall with a rate of 214lbs/in; and rears that are 16 1/2" tall with a rate of 116lbs/in. And 9 & 10 coils, respectively.
On pitstopusa.com, they have their springs organized by front and rear sets and you can mix and match to get your desired ratios. Depending on brands, the front springs range from 8-12" in height and rates of 500-1500lb/in. Rears range from 8-16" in height and rates of 100-500lb/in.
The IAP spring rates seem kind of low to me(keep in mind that I'm not afraid of a stiff ride, and would gladly sacrifice some comfort for greater handling/maneuverability. Fast corners make me happy.) in comparison to what I have found on this site, and from what friends of mine run in their cars.
1)What exactly defines the spring rate?
2)If I increased the spring rate, could I use a slightly shorter spring and maintain the same height as a softer, but taller spring?
3)Is there any physical difference between front and rear springs? Or is it most likely just organized as such on the site to group springs of similar size/rates?
4)The rear springs on both pitstopusa, and IAP seem dramatically softer. Why?
5)What is the ideal ratio of front:back rates?
6)What is the max spring rate I should use?(I'm assuming if it gets too high, I run the risk of damaging the shock towers)
7)Anyone know the stock rate?
8)Any other information you feel I should know, or would like to share?
Keep in mind that I'm looking to be educated, and I'm not going to pretend that I know what the best solution is so feel free to give me any feedback you like(as long as it's flame free
I'm also hoping this thread could serve as a collaboration of questions/answers about upgrading suspension for those of us who don't come from racing pedigrees
