Well I’m doing the big move from Colorado Springs, CO to Sacramento, CA (Cameron Park area). It's a 1250 mile drive. I'm running thru the car to make sure i can not only make it but drive after. I have two mountain passes so I’m a bit nervous. I've completely replaced the cooling system (radiator, water pump, thermostat, hoses, and fan) and added (2) 1550cfm electric fans as well, replaced the front brakes with rotors and pads, break fluid flush, replaced the top, did a royal purple oil change, new tires, spare plugs, plug wires, coil, battery, H.I.D head lights, heat wrapped the headers, new exhaust, new timing and accessory belt, checked timing is correct, new fuel filter, all new front suspension and almost new rear suspension, alignment, I’m doing a transmission flush with GL-1, I’m doing a differential flush with 80w90. I'm not sure what else I need to do or should check for as this 1979 2000 is still new for me. She runs and feels great. Any suggestions would be fantastic. Once again thanks for all the help I really couldn't have done all this without everyone’s help and guidance so far. I know I can count on all of you!
