Clutch cable installation tricks?
hdhracerx
Post by hdhracerx »
Replacing the broken one in my 73 this morning I found it too difficult to get the cable end properly inserted into the pedal recess.
Very little access up in there and the distance in the gap at the very end seems too snug to easily drop it in. I am able to get it very close, but because there's no apparent way to pop it in from the top, it's not going to drop into place by itself.
After an hour and a half I gave up. Any tricks I should be aware of. HAVE to get it in this eve so I can catch a flight in the morning!
thanks!
hdh
77SportSpider
Re: Clutch cable installation tricks?
Post by 77SportSpider »
It's very difficult, I've done it a couple times now. So far I'm not aware of any tricks other than having small and flexible hands. Persistence and patience will help too.
hdhracerx
Post by hdhracerx »
Appreciate the thought - ran out of time this morning... Will be getting some better light under there and going back at it this eve.
How about the pedal spring removal? I think perhaps if I could get that spring off the clutch pedal, I'd have the room I'd need to move. Seems too stiff to remove it so far...
hdh
Online
Baz
Your car is a: 1977 Fiat Spider
Post by Baz »
As far as the spring goes, I received a great tip here some time ago. I could not get the spring fitted to the pedal. The tip was to put the spring in the vice and bend it over placing a 20c coin in each gap, then bend the spring the opposite way and do the same which will stretch the spring out. I then took it out of the vice with coins still attached and simply put it in place and pulled out the coins. Simple !!
You will be able to do this by pushing the pedal down and then put in the coins. At least that will get the spring out.
Good luck
Baz
kmead
Your car is a: 1969 850 SC 1970 124 SC 85 X19
Post by kmead »
First do not remove the spring. If the spring has broken replace it, but there is no reason to remove it to replace the cable.
This is one of those patience things. Its best to have a second person pushing in on the cable sheath from the engine compartment. Put some dishwasher soap or hand soap on the rubber grommet to get the cable sheath to stay in the hole. Then slide the cable itself as far into the pedal well as you can from inside the car (the threaded end by the transmission will limit the amount of cable you can pull in.
Put the cable end barrel down into the slot so the barrel is horizontal, making sure the cable itself is in the "fork". Using a screwdriver push the cable end barrel into the recess completely so the cable goes through the "fork". I was able to use a small pair of locking pliers (the long thin nosed small vice grip) to push/drive it into the recess. Once it is fully seated it can rotate to allow the cable to always face the opening in the firewall.
It is very easy to jam the barrel vertically into the fork, it needs to be horizontal (perpendicular to the opening of the fork).
Karl
1969 Fiat 850 Sports Coupe
1970 Fiat 124 Sports Coupe
1985 Bertone X1/9
adrians
Your car is a: 1981 Spider Turbo - missing the turbo
Post by adrians »
Timely advice - I have to do my clutch cable on the weekend !
Also be aware that there are some 124 clutch cables that are shorter than others ( as I discovered ), these cables are for the 124 sedan and wagons with OHV engines - this is only applicaible for RHD cars.
THE FLEET
2014 Abarth "SS"
1981 Spider 2000 (Legend Industries Turbo - minus the Turbo)
1978 X1/9 1.3 Dual IDF 40's, Coupe Cam, Allison Header/Exhaust
1971 128 Sedan 1100cc, Coupe Cam/Headers
Motokhana Special 127 rear engined Rail 903cc
SLOSpider
Post by SLOSpider »
Its been too long since I have done one but my new one should be here tomorrow so Ill let you know. Maybe its easier to just remove the pedal then install it...
1975 124 Spider
1989 Chevy k5 Blazer
1967 GT Mustang Fastback
Curly
Your car is a: 1968 AC Coupe and a 1976 CS1 Spider
Post by Curly »
SLOSpider wrote:Its been too long since I have done one but my new one should be here tomorrow so Ill let you know. Maybe its easier to just remove the pedal then install it...
That's the route I took with the last one I installed :roll:
Somtimes the fork prongs at the top of the clutch pedal crack or bend, so i've reinforced the fork on both my 124s by welding in some additional gusseting. This unfortunately makes fitting new cables even more difficult, especially if the pedal in still in situ - but at least they are less prone to flexing and cracking. :wink:
