Page 7 of 7
Re: South Pacific spider restomod begins
Posted: Wed Jul 20, 2022 4:36 am
by Kiwispider
Posted: Wed Jul 20, 2022 2:28 pm
by TX82FIAT
Great work, beautiful car!!
Posted: Wed Jul 20, 2022 7:34 pm
by davebdave
Wow! That's amazing. So pretty!
Posted: Thu Jul 21, 2022 6:07 am
by Anbele
Bravo!!! Beautiful work!!! Long live The Fiat 124 2000!!!
Posted: Sat Jul 23, 2022 10:07 pm
by DRUMMOND
What a beautiful car!!! well done. Now Go Enjoy!!!
Posted: Thu Jul 28, 2022 1:11 am
by Kiwispider
Thanks for all the nice comments.
I noticed after a couple of short runs that oil was leaking past (as in all the way around) the new sump gasket. From what I'd read the jury was undecided on whether gasket sealer was necessary, so I didn't. Also, my handbook says the sump bolts should be torqued to 6 ft-lb. My torque wrench doesn't even go that low! Giving the sump bolts a tweak showed just how lightly tightened they were, don't know if heat expansion might have played a part? Hopefully nipping all the bolts up a bit tighter than spec will stop the leak and not cause any problems.
Update on the ride height with Vicks Hydrasport shocks and progressive springs - the front is now 10mm lower; the rear is 25mm lower; the front is 10mm lower than the rear when measuring to the underside of the sill. Not perfectly level but so close you can't tell. Aesthetically I'd like it a little lower, but that can wait for another day.
