Page 7 of 19
Re: 1980 spider Restoration phase 2
Posted: Sat Jan 14, 2017 8:20 am
by AriK
Ok, sorry, my bad, i see you documented that repair on page 2. You eliminated those quirky captive bolts inside the rail and installed long bolts from top to bottom. Fiat should have done that from the start but i guess the extra holes would have created a stress point. If they beefed up the area in in the first place as you did...
My right inner fender has similar uneveness as yours shows, either by a hit or the tower is slowly starting to lean in. In any case my alignment guy notices the camber cannot be put into spec by slight but compensates another adjust somehow to keep the steering from pulling, (not sure of the exact detail). What i do know is the car steers dead on and there's no uneven tire wear.
Posted: Sun Jan 15, 2017 12:59 pm
by Frankd1
Drummond, looking really good! Do you have a link to all of the various photos for your restoration, or is everything in this thread?
Here's something that might provide some info regarding that wrinkled section in the engine compartment, at the top area of the shock mount:
https://m.facebook.com/groups/154869514 ... 0917770900
It was a thread that was started and talks about the possible causes and the fix
Posted: Sun Jan 15, 2017 3:22 pm
by spider2081
Jim would you happen to have a photo of how the door window cable is wound on the electric motor capstan??
Posted: Sun Jan 15, 2017 10:50 pm
by DRUMMOND
Frankd1
Not a facebook member. but Thank You!
Here is the link
http://s1124.photobucket.com/user/smudgren/story
2k+ photos, be patient
Spider2081
Posted: Mon Jan 16, 2017 7:34 am
by spider2081
Thank you so much. I believe the capstans on mine are shot. There was a lot of corrosion on them and just spraying them with WD-40 I can see the ridge separating the winding's is about 1/2 as high as yours. I think that is contributing to the cable jumping out of place
Thanks again Jim
I marvel at your attention to detail as well as you accomplishments. Great job on your car.
Posted: Mon Jan 16, 2017 6:28 pm
by Frankd1
Thanks, I'll take a look at them..
Did you actually separate all of the skins from the hood, trunk doors etc?!!
Posted: Mon Jan 16, 2017 9:56 pm
by DRUMMOND
Hi frankd1
I separated the hood and the trunk. if I did not they would have had to be scrapped, as there was way too much rust inside. I was not going to paint with that hovering over my head. Plus I only took on this project as a low budget affair, repair as much as possible, replace as little as possible.
The doors I only replaced the bottom halves.
The hood and trunk separation was an easy project. you just have to get over the separation anxiety
The reconstruction of the drivers fender and inner fender was a pain in the *** took a loooong time, lots of measurements time and time again.
You may have some of your guide wheels rusted frozen.
Posted: Tue Jan 17, 2017 9:08 am
by Frankd1
That's the only way to truly get at it all...plus you can seal everything up with masterseries silver or por15 and never have to worry about it again!
Great work!
Posted: Tue Jan 17, 2017 10:40 am
by spider2081
Actually I have mechanical windows on my car. The electric motors assemblies I have are spare parts I just happen to have. One of them had the cable jammed and crushed between the capstan and the housing. The cable is too bent up to use. When I wind good sections of cable into the groove I was thinking the groove was too shallow. I worked in aviation and aircraft autopilots use similar setups with cables and capstans. I was use to seeing much deeper seating of the cable into the groove on the autopilots. I wasn't sure if my memory was failing or if what I have is they way it should be. Your photos show a much deeper seating of the cable into the capstan groove so I guess the two I have are worn out. The motors themselves seem to test good. I haven't taken the motors apart to clean and lubricate them yet.
Posted: Wed Jan 18, 2017 11:28 pm
by DRUMMOND
Posted: Thu Feb 02, 2017 10:37 pm
by DRUMMOND
Posted: Fri Feb 03, 2017 8:51 am
by aj81spider
That's beautiful. I'm following this thread in awe of how you are transforming every part of the car!
Posted: Sat Mar 11, 2017 11:34 pm
by DRUMMOND
Posted: Sun Mar 12, 2017 12:15 am
by nelsonj
Very nice color. I look forward to seeing more pics!
Posted: Sun Mar 12, 2017 12:26 am
by So Cal Mark
what is the emblem you've added behind the front wheel opening?
