Page 28 of 55
Re: Edit... Resto mod coming together
Posted: Sun Aug 17, 2014 5:12 am
by Daniel
Hey 81spidermatt what kind of international do you have? a friend of mine used to race one off road of course.
I was apart of the pit crew a couple times.
Posted: Sun Aug 17, 2014 9:58 am
by 81SPIDERMATT
Daniel wrote:Hey 81spidermatt what kind of international do you have? a friend of mine used to race one off road of course.
it is a 1976 scout II ...project glacier my roomate calls it .... 2 plus years and counting .... it will be a quite sturdy and capable camping / exploring rig .... lifted ... tires... comfy ... ... the list is extensive ... the area i live in actually has quite good road systems to get you out there ... excited to see the spots that the scout will now open up past those roads
Posted: Sun Aug 17, 2014 4:52 pm
by SoFlaFiat
Ohh, I'm having fun now!!
Crank in with new bearings and thrust washers
Rear seal done, lightened steel flywheel torqued down
And front coming together with new seals, gaskets and BLING
Posted: Sun Aug 17, 2014 8:41 pm
by 2500diesel
Just read this whole thread.
Sir, I salute you. The quality of your work is marvelous.
Posted: Sun Aug 17, 2014 8:58 pm
by SoFlaFiat
Thanks!! At this point, a year and a half into it, I am getting really excited about the final product! I have been thinking about this build for 20 years and it is coming out exactly as I wanted. Just crossing my fingers I can make it run and not just look good.
Posted: Mon Aug 18, 2014 7:29 pm
by SoFlaFiat
Quick update,
This is the first time I have side mounted an engine for a rebuild and I have to say, it is fantastic!
I stood it up on end and installed the clutch
Then spun it round and installed my tensioner
Then I got my new pistons installed on the con rods
A little progress every evening and I'll have this thing all bolted up to the trans and on my cart over the weekend.
Posted: Mon Aug 18, 2014 10:35 pm
by vandor
Aren't you going to paint the engine block?
Posted: Tue Aug 19, 2014 5:55 am
by SoFlaFiat
Ha, I guess I picked the right color if I was going for the "old Italian iron".
It's painted Csaba, gunmetal metallic.
Posted: Tue Aug 19, 2014 6:19 pm
by SoFlaFiat
I have to check fluids on the 77 today and drive the kids to fencing practice so no time for the project today but this did come in
Ignition porn!!
Posted: Tue Aug 19, 2014 6:46 pm
by Ptoneill
The engine looks great, I was wondering about your pulley alignment compared to mine. I am using the 65 amp alt on the passenger side, I had to use the inside pulley track.....see photo. Are you using the 95 amp? It just looks like your water pump is using a shallower pully.
I like the side mount motor stand!
Posted: Tue Aug 19, 2014 9:19 pm
by SoFlaFiat
Wow!! Look at all that sexy red stuff!! I had a chat with Beek today and we came to the conclusion that every little bit of red on the car adds horsepower!! Beek says chrome does too!!
Looks great Pat!! But! If you really wanted to go fast, you would have matched that paint! What did it say? 640HP ? See? Proof!!
In any case, I have a middle groove main pulley and it looks like you are running a first groove. The water pump pulley corresponds in both our cases. I think I did my research and ordered what I needed but to be honest, I might have the wrong stuff
I will hang my alt tomorrow, yes a 95, and see if I have to change out one or some pulleys...
Posted: Tue Aug 19, 2014 9:22 pm
by fiat218
SoFlaFiat wrote:Wow!! Look at all that sexy red stuff!! I had a chat with Beek today and we came to the conclusion that every little bit of red on the car adds horsepower!! Beek says chrome does too!!
Lol my 69 is red, but I need to change the color in the engine bay,way to much power beek said, yellow will hold it from flying
Posted: Tue Aug 19, 2014 9:28 pm
by SoFlaFiat
See? I told ya!!!
Ok, anyone have a 38 ADL for sale?
"But then again, running IDFs is like buying frustration. Especially on anything bigger than the 1608. They are going to run like crap 99% of the time, and then you convince yourself its running great and you tell others how great they are. This is what we call the acceptance phase. At some point down the line you ride in someone's car without IDFs, say a fuel injected Spider or one with a big ADF, and you put the IDFs on ebay. We call this the freedom phase."
I'm heading straight to the freedom phase!!
Posted: Tue Aug 19, 2014 11:29 pm
by vandor
SoFlaFiat wrote:Ha, I guess I picked the right color if I was going for the "old Italian iron".
I would paint the machined surfaces that will not have anything attached, as they will rust unpainted.
Or are you planning on your engine leaking enough oil to keep rust at bay?
Cs
Posted: Wed Aug 20, 2014 6:01 am
by SoFlaFiat
That Hungarian humor!!
Yep, I'm depending on lots of oil...
Actually Csaba, I painted the whole thing (except front and back) then polished the machined surfaces and used high temp clear on the whole thing except the front and back. After it is completely assembled, I will spritz the machined areas on the front and back with INOX which should help keep the rust at bay. In a year, I'll do a write up on the use of Inox, after I know whether it works as advertised.
