Finally something to show
juvius
Your car is a: 79 spider
Re: Finally something to show
Post by juvius »
i really wanted to use the stock fan with the texas heat radiator that i bought, but since the radiator is thicker, and even though the radiator was designed to mount the stock fan, the fan touched the water pump pulley. So i ordered a slim aftermarket fan. It came in today and i like it. it's definitely a lot thinner than the stocker. I'm going nuts not having my car here to work on, so i'm trying to keep busy with as much stuff as i can.... :|
fiat218
Post by fiat218 »
Where did you get it at, I may need one too
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
BEEK
Your car is a: 1975 Spider
Post by BEEK »
yes jim you may, but dont order one yet, if we do change the fan i will use a pusher fan from the front, to give more space as the 1438 radiator panel is different than the others
75 spider
son has 78 spider
btoran
Your car is a: 1975 Fiat 124 Sport Spider
Post by btoran »
that looks very similar to an aftermarket one i bought. in addiiton to moving more air, it is virtually silent. how did you mount the fan to the radiator?
1975 Fiat 124 Spider
fiat218
Post by fiat218 »
BEEK wrote:yes jim you may, but dont order one yet, if we do change the fan i will use a pusher fan from the front, to give more space as the 1436 radiator panel is different than the others
ok, got it
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
juvius
Post by juvius »
btoran wrote:that looks very similar to an aftermarket one i bought. in addiiton to moving more air, it is virtually silent. how did you mount the fan to the radiator?
it came with a mounting kit. there are square rubber sticky pads you put between the radiator and the fan, then you put a long zip tie through the fins. from the back you slide more rubber sticky pads then slide a circular clip that locks onto the zip tie.
juvius
Post by juvius »
fiat218 wrote:Where did you get it at, I may need one too
i got it off ebay for $25 shipped. this one is 14inch. if you do need one, you might need a smaller one since you have a smaller radiator. it's been so long since i looked at a smaller (early) radiator that i can't remember if 14inch would fit or not.
MrJD
Your car is a: Looking to ask questions about a 79 2.0
Post by MrJD »
crap... thats cheap. Tempting.
juvius
Post by juvius »
MrJD wrote:crap... thats cheap. Tempting.
i havent' heard it spinning yet.. don't rush off to get one until i find out if it's good... sometime you get exactly what you pay for...
juvius
Post by juvius »
i just was out in the garage with my jump pack comparing the stock fan and the aftermarket fan. They both seem to move about the same amount of air, but the aftermarket one is quite a bit quieter. i'm happy with it.
fiat218
Post by fiat218 »
juvius wrote:i just was out in the garage with my jump pack comparing the stock fan and the aftermarket fan. They both seem to move about the same amount of air, but the aftermarket one is quite a bit quieter. i'm happy with it.
Thank God that your happy, now I can sleep , :D g nite
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
juvius
Post by juvius »
Damn it, Jim!!!!!! :twisted:
juvius
Post by juvius »
accelerator linkage and front indicators cleaned up pretty nice (thanks to autoricambi for the quality clear lenses): (this also makes me happy, jim!!! :D ) Though i'm thinking about replacing the amber bulbs with a chrome amber bulb so you won't be able to see orange until the lights are on.. just not sure if it really makes a difference...
MIGHTY 8
Your car is a: 1980 Spider
Post by MIGHTY 8 »
juvius wrote:accelerator linkage and front indicators cleaned up pretty nice (thanks to autoricambi for the quality clear lenses): (this also makes me happy, jim!!! :D ) Though i'm thinking about replacing the amber bulbs with a chrome amber bulb so you won't be able to see orange until the lights are on.. just not sure if it really makes a difference...
Man! Every time I stare at my tired old linkage atop the cam housing...I either want to circumnavigate it to somewhere else, or at least make it look good! You did the latter and it looks great!
juvius
Post by juvius »
Thanks. It was a little rusty so I soaked it in a tub of muratic acid over night. Came out looking new but I had to paint it because even though the acid removes rust, it causes rust at the same time.
