I've tried every off the shelf grease, anti squeal compound, cleaner, etc I can buy. Applied it on every surface possible in every combination possible, nothing has stopped it. The squealing happens at two different temperature ranges. The first being when it is nice and cold out and the car is being driven for the first time in 12+ hours, it'll squeal for the first 2-3 stops coming out of my street, and then stop for awhile. Then once the pads reach true operating temperature, after about 30 minutes of stop&go traffic or a few stops from moderate speed on an decline. This is the most annoying stage of squeaking because it'll keep doing it until the brakes cool down significantly or get significantly hotter, which doesn't usually happen until I reach whatever destination I'm going to.
I've also bought the wilwood anti vibration shims as suggested by a few other members in the past, and while they made the squealing happen a little bit less, it definitely didn't solve the problem
maytag wrote:boogiedude wrote:
What did it cost, if you dont mind my asking? I have a wilwood setup that works very well but it squeals and nothing that I've been able to do has been able to stop it. At the point of looking for a different setup
Sell me your wilwood setup?
I'll sell it to you if and when I get another setup
