Cutting Springs
Re: Cutting Springs
I like the KYB GR-2 shocks for street use. As long as the springs aren't collapsed there isn't any extra load on the shocks. Shocks merely dampen the spring action
Just read a trade journal article about cutting springs today, and they say not to use a torch. "Never use heat to cut a spring. The heat from a torch will change the structure of the steel. You will either end up with completely useless springs, or springs with a greatly shortened life."
The other suggestion is about finishing; Powder coating and chroming can ruin the spring if not done properly. Powder coating has to be done below 350F or the springs will anneal and will not support weight. Chrome springs can suffer hydrogen embrittlement and shatter.
Re: Cutting Springs
Anybody have a pic of a late model after cutting 1 coil in the back and 2 in the front? im curious!!! do you still keep your plastic cover on?
- TulsaSpider
Re: Cutting Springs
KK thanks MarkSo Cal Mark wrote:I like the KYB GR-2 shocks for street use. As long as the springs aren't collapsed there isn't any extra load on the shocks. Shocks merely dampen the spring action
- Your car is a: 1981 Spider Turbo - missing the turbo
Re: Cutting Springs
FiatColombia1,
I'll have pictures (before and after) of my Spider after it gets new front springs and cut rear springs on Tuesday this week.
THE FLEET
2014 Abarth "SS"
1981 Spider 2000 (Legend Industries Turbo - minus the Turbo)
1978 X1/9 1.3 Dual IDF 40's, Coupe Cam, Allison Header/Exhaust
1971 128 Sedan 1100cc, Coupe Cam/Headers
Motokhana Special 127 rear engined Rail 903cc
2014 Abarth "SS"
- TulsaSpider
Re: Cutting Springs
My shocks which I believe are original seem to be in good shape as far as the traditional bounce test determines. Would I see any significant benefits in changing them out to the KYB's?
Re: Cutting Springs
if you're using the original oil shocks, the KYB's are a great upgrade
Re: Cutting Springs
I have heard of KYB's raising the car from the gas pressure, have you had an issue with this? No shock tower issues from the increased pressure? thanks
Trey
Re: Cutting Springs
Trey, the KYB Gas-a-just (white) are heavily gassed, and raise the car. The KYB GR-2 are more damping and have minimal effect on raising the car.
Re: Cutting Springs
Cool, that must be where the confusion came from.
Trey
Re: Cutting Springs
I had to tell someone!! I just lower the back of my '83 and took me 10 minutes!!!
1.I jack my back left tire as high as it will go
2.took tire out
at this point there is almost no pressure on the spring
3. cut one coil of the top with a grinder with a low heat disk at the same point where original ends so that it matches the seats.
4. once that coil was loose cut it again in half for removal.
5. put tire back on and lower jack.
1 to 5 on the other side and Done. looks beautiful!!!
Now the front will be another story, I'm taking Mark's suggestion and cutting one in the back and two in the front.
Not many improvement will take you 10 minutes and have such a nice impact.
2.took tire out
- Tappy
Re: Cutting Springs
i bet a picture says more then 1000 words ....FiatColombia1 wrote:I had to tell someone!! I just lower the back of my '83 and took me 10 minutes!!!
2.took tire out
FineItalianAutomobile Technology
- jfrawley
Re: Cutting Springs
So finally got around to cutting the rear springs. Went over to fellow DC Fiats member John Erskines house. Now, let me tell you, if I ever get into some real money, I want a spot like his. 4 car garage with a lift, bead blaster, air compressor, and every tool known to man. We pulled out the old springs and shocks, cut the rear springs down 1.5 coils, installed new KYB's, and it lowered the back about 1.5 inches-perfect. We tried a set of 1969 springs but they were too short and too soft, so they lowered it a bit too far. When I re-do the front suspension, I'll take a coil out of the front as well.
Before
After
Thanks John, DC Fiats comes through again.
Before
After
