Weber 32 ADFA rebuilding question
Topless
Your car is a: 1979 Fiat 124 Spider 2000
Re: Weber 32 ADFA rebuilding question
Post by Topless »
wetminkey wrote: I believe that the main jet resides behind the power valve housing and diaphragm.
Are the two main jets the brass ones inside the base of the tank that the float sits in? I see part 13 on an exploded ADFA parts list but it is just floating in space, without context.
PaulC
Patron 2022
Patron 2022
Post by PaulC »
Topless wrote:
PaulC wrote:As promised a link to my ADHA rebuild write-up:
https://drive.google.com/open?id=1DLaHY ... LPJhnPPROL
This link appears inactive. Any way to renew it?
Try this instead
https://www.mirafiori.com/forum/viewtopic.php?t=98334
Its for an ADHA but nearly identical to the ADFA.
PaulC
Patron 2022
Patron 2022
Post by PaulC »
And yes, the two main jets sit inside the float bowl. The two outside the bowl are the air corrector jets.
