Weird running issues
- Your car is a: 1982 2000 Spyder
Re: Weird running issues
I have spark, but the injectors aren't firing. I thought it was a spark issue, but testing since has revealed that the spark is fine.
Current vehicles:
1982 Fiat 2000
1975 Porsche 914 2.0L (in pieces)
1987 BMW 325e
2002 BMW 325iT
2006 MB E350 Wagon 4Matic
2011 Toyota Tundra SR5
1997 Mazda Miata M-Edition
1984 VW Rabbit GTi
1982 Fiat 2000
1987 BMW 325e
2002 BMW 325iT
1984 VW Rabbit GTi
- 124JOE
do a search on the forum
afm and duel relay
the more you learn on here the better you will be
afm and duel relay
The AFM is fine. It was just rebuilt and activates the fuel pump correctly.
As for the dual relay, I do need to learn more about it.
Also, as stated before, the resistsnce from the 13 pin to the temp sensor is way out of range!
Current vehicles:
1982 Fiat 2000
1987 BMW 325e
2002 BMW 325iT
1984 VW Rabbit GTi
1982 Fiat 2000
1987 BMW 325e
2002 BMW 325iT
1984 VW Rabbit GTi
- 124JOE
try unpluging the temp sensor at the radiator
So, after a little digging I FINALLY got to the bottom of my running issues and here is what I found:
There was no pulse at the injector, so this led me to believe that the ECU wasn't grounding the injectors. I checked the wiring at the ECU and found a couple of wires where the jackets had burned and were contacting each other. I repaired the wires, but still was not getting any pulse from the ECU. I figured I had a bad ECU, which I did.
I opened up the ECU and found a burn mark on the circuit board for pins 13 (temp. sensor) and 14 (injector). I tested the resistance between the 2 points on the circuit board and got open resistance. So, rather than spending the money to get the ECU rebuilt, I decided to try and fix it myself, figuring that if I couldn't fix it, I could still send it off. So, I got my soldering iron and re-soldered the three points on the board back together, re-installed the ECU, and BAM!, the car now runs.
This being said, I still need to drive the car for a little while to claim victory, but at least I'm heading in the right direction. Now all I need to do is re-install my rebuilt calipers and new braided lines and do a shake down.
I hope this helps. The only thing I can't figure out is what caused the wires to burn their jackets, cross each other, and burn up the ECU and AFM. Any ideas? Faulty dual relay?
Current vehicles:
1982 Fiat 2000
1987 BMW 325e
2002 BMW 325iT
1984 VW Rabbit GTi
1982 Fiat 2000
1987 BMW 325e
2002 BMW 325iT
1984 VW Rabbit GTi
- Patron 2019
Congrats! Nice repair.
With one side being ground, melting wires come from a short to a12volt circuit that has no fuse, or a hi amperage fuse greater than the ampacity of the wire that melted. Sometimes people troubleshooting inadvertently put 12 volts or ground at the wrong places. Or plug things in incorrectly. Not sure the history of your not running? Maybe caused by a previous owners actions?
Current 81 Spider 2000
Previous 76 Spider
Previous 76 Spider
That's what I'm thinking, or maybe a little furry creature as I'm in the country surrounded by fields. It was just a sudden issue, and the car had been sitting, I didn't think it would be that catastrophic! So far, the repair seems to be holding up, and it gave me the chance to fix a few other things. I just need t figure out what to put on the solder to prevent corrosion.
Current vehicles:
1982 Fiat 2000
1987 BMW 325e
2002 BMW 325iT
1984 VW Rabbit GTi
1982 Fiat 2000
1987 BMW 325e
2002 BMW 325iT
1984 VW Rabbit GTi
