Roy - what kind of lights did you install in your grill. Can you post a shot of the nose?
These are the light I have currently:
Nope. I put IAP reds on with KYB shocks and the car did sit high. I cut 1.5 coils off the rear and it came down nicely.fiat218 wrote:So in order to lower the car, the springs have to be cut?
No problems here with bottoming out except for the worse dips in the road. I have no regrets with my decision to lower my spider.
I had asked a member here about the same time I installed the 1" front and he mentioned that with the rear bar and hard/fast cornering, likely racing conditions, the inside rear tire might lift. I can't imagine in day to day driving that happening too much myself. Also there have been several threads about the rear bar and it seams the underlying issue for some was the pita installation. I have not driven a car with a rear bar so don't know first hand any improvements...giuliot60 wrote:So narfire, I heard if you put a thicker sway in the front you should install a sway bar in the rear. Thoughts?
