Dyno Day in So Cal
Shows, meets, organized drives, club info
spiderrey
Re: Dyno Day in So Cal
Post by spiderrey »
its going on right now, just got back, there werent even 10 cars there to dyno.
those who did make the Dyno Day had a good time and most of the cars found some more hp with adjustments between runs. For the most part it was very informative and entertaining, and the bbq was good. Pics and vids will be posted soon, along with some results. The cars ranged from bone stock to various mods.
mdrburchette
Post by mdrburchette »
That sounds like so much fun, Mark! I may have to cajole the local shop into letting our club do something like that.
it was worth the effort for those that attended, and the dyno shop guys made a few bucks too. There were 4 non-Fiats there and that made the event a little more diverse; a Porsche Cayman, BMW Z3 M, MB 500E with a 100 shot of nitrous and a Volvo. All 4 of them were putting out rear wheel hp in the 280-300 range.
Most of the interest in the Fiats was seeing what a completely stock FI 2.0 put out and seeing what hp some small changes induced.
For instance, a cone type air filter added 1 hp to a 2.0 FI car while an extra 4 degrees of initial timing added 4 more hp. Simple tweaking of the afm added between 3 to 5 hp to mostly stock FI cars. And of course, comparing a/f ratio changes with and without aftermarket air filters
spiderrey
Post by spiderrey »
What happen with Hals coupe after I left?
halg
Post by halg »
The good news was that 3PSI boost made 20HP the bad news was that it only made 3PSI boost. So far I can find no mathematical reason for less than 7PSI boost. Something mechanical will require a teardown. I guess that 79HP from a 8.2CR 1608 isn't bad either.
Hal
here is a bit of video I got before the batteries ran out
http://www.youtube.com/watch?v=3Iixm9dXU6Q
Zippy
Your car is a: 1978 Fiat
Post by Zippy »
Thanks Mark for taking the video and getting it posted. Almost like being there, just without the fumes. I really wish I could have been there. Were those all stock motors or did any have mods?
Also, looks like luggage racks are popular there.
Al
1978 Spider
rlux4
Patron 2022
Patron 2022
Post by rlux4 »
What was the stock HP on the FI car(s)?
Ron Luxmore
rlux2n2@gmail.com
Razooli
Your car is a: 1982 Fiat Spider 2000
Post by Razooli »
My 82 Spider is bone stock with timing set at 10° BTDC with a stock airfilter ... here's the printout of the four pulls.
http://flic.kr/p/8sYgAW
The power differences between the first pulls and last pull (in red) were due to Mark tinkering with the AFM settings.
http://flic.kr/p/8sVevv
This car also has non-functioning AC. I pulled the belt years ago, but someone replaced it when it was serviced at some point in time, so the engine was turning the compressor during the pulls. Disconnecting that belt and bumping the timing a few degrees would probably give a couple more HP.
Many thanks to Mark for setting this up. It was a VERY informative session and the cheezburgrs wuz gr8! :D
Lynn Shuler
1982 Spider 2000
Remember, this hobby is supposed to be your therapy, not the reason you need therapy.
rlux4
Patron 2022
Patron 2022
Post by rlux4 »
Very interesting. Thank you Razooli.
Ron Luxmore
rlux2n2@gmail.com
Razooli
Post by Razooli »
rlux4 wrote:Very interesting. Thank you Razooli.
Sorry you didn't make it. I was looking forward to some of that "world famous potato salad"! :D
Lynn Shuler
1982 Spider 2000
