ex ufficial car Tominz-Mamolo female european champions '71
no images of the engine....sorry
mdrburchette wrote:I thought the rally version was a 1756 cc but I've been wrong before. 155 hp at the flywheel? That's a heck of an engine! My 1608 is around 120.
I meant 155 (DIN)...I suppose if you add the 5% you get the SAE power at the flywheel.wmausbach wrote:Wow 155 Din Hp at the rear wheels translates to 178Hp at the flywheel (assuming 15% loss). Or did you mean in comparsion to SAE rating which is more like 5% difference? In any case if you use the same Hp to CC ratio for the 1756 if gets about 170Hp. It jives with quoted Hp for the Abarth two valve. It only makes sense that the factory would use their experience with the 1608 to the bigger 1756cc motor.
This should be the lift: 4,70 intake. and 4,55 exhaustwmausbach wrote: The cam data is great and is the first time I've seen the competition specs for the 1608 or the later Abarth two valve. However can you get the lift too?
wmausbach wrote: Your sources are the best. What we call down here in Texas " Strait from the horses mouth" .
